devildogadam
So I was sitting at a light on my way home enjoying the wonderful 29palms heat when all of the sudden my truck went wide open throttle Balls to the walls. I was lucky to have my foot already on the brake, I stomped on the brake pedal and she poored black smoke and started to spin the tires. Cars all around where terrified. I kept my foot on the brake and pumped the fuel pedal a few times then after a bit it quit. But then I had no throttle response. Shut it off and restarted it would rev up and run away. Then after a few more restarts it would idle fine but no real throttle response would only do about 10mph and misfire and rev and stall. Pulled over and let it sit for about 15 minutes then it ran fine on the way home. This is the first time it has done it in drive but lately when idling it would randomly rev to red line then back like someone was snapping the throttle. The only code it threw was a code 35. So I am at a bit of a loose
