maximsafety
Big red
Greetings all, I just joined and I see there is a ton of knowledge out there. I am hoping someone can help me with my problem. I've got a 1995 Silverado 6.5 TD 3500 dually, when I bought the truck the previous owner had installed a glowplug overide system and it worked fine until recently. The system is now giving me short run times as the stock configuration, I repalced the bypass relay and the system worked again as designed within one week it stopped working again! Replaced relay again, work fine, this time days later failure! What the heck am I missing! Also replaced the glow plug controler, glow plugs. The fuses are good, grounds and connections are good. Any advice would be appreciated!:mad2:
1995 Silverado 4X4 one ton dually Marine injectors, turbo boost controller, 4" exhaust, cold air intake, #9 resistor, Heath HPT chip, and much much more:smile5:
