btfarm
America First!
Made your pics full size again. Select that option when you attach them.
And BTW, that's a mighty nice lookin scooter!
Thanks...that's all my work...hope I can make this project look good. Now to try and find that option..new guy blues!Made your pics full size again. Select that option when you attach them.
top pic is side. botton pic rear door.View attachment 54553
And this on the rear access door.
View attachment 54554Planning on this graphic on the side
Figured on the AC Delco since this won't be a daily driver. Maybe 10k miles a year tops. Gotta work sometime! The belt is a no brainer plus it's shot. Looks pretty bad. All new hoses too.Get the stock injectors from Leroy. Without doing a ton of hot rodding to an engine, marine injectors simply are not needed. Marine injectors are to push massive fuel at high rpm. The factory injectors can push more fuel than your current build needs.
Give it a bit of looking to fine the relay thread. I suggest adding the switch like Leroy does it to assist primingvafter filter changes.
Fuel lines in stainless are best. Any flexible lines should be SAE30R9. 3/8” supply, 5/15” return. Most factory feed is 3/8” from tank through LP to filter. Then it reduces to 5/16. This is an error in design or possible cost savings in manufacturing. Having it go to the ip in 3/8 is best- this modification is known as ‘feed the beast’. Depending what liftpump and filter you are running determines which fittings you need. Picture of filter housing helps determination.
Something I forgot earlier, the belt drive should be repalaces at same time as balancer. If you invest the big money in the fluidampr, I suggest Leroy’s billet pulley. If not going to spend the big bucks, just get an AC Delco.
Found some SS tubing on eBay in 5/16 and 3/8. planning on Leroy LP Carter. Should I use Flair or compression fittings. I have a single flair tool or I have a boat load of compression fittings. I like compression but what do you think?Get the stock injectors from Leroy. Without doing a ton of hot rodding to an engine, marine injectors simply are not needed. Marine injectors are to push massive fuel at high rpm. The factory injectors can push more fuel than your current build needs.
You see its tidbits of information like that last fitting that makes your advice special. ThanksMan, your in trouble if you like my advice! Everybody that answered before me are folks I trust more than myself btw.
Whatever fitting you like is what you will get best results from. Both hold WAY over the max pressure and vibration.
iirc The fitting into the ip is special- so order from Leroy.
Which injectors should I get? I have read the marine injectors are a good bet. What is your opinion?
I'll be hauling my 1986 Suzuki Samurai . . .
Thanks for all the insight. Engine ran cool this summer when I bought it. Had a compression test run on it pre purchase and it had all good numbers. Temps were normal but I never really put much load on the rig. Only thing I could find wrong was a very little oil weep on the turbo cross over and some around valve covers. Overall a pretty clean tight engine. I think fleet maintenance played a large roll in its life. At least that’s my hope.If you are doing the water pump you may as well do the timing chain. Get The Leroy Diesel gear set to eliminate the sloppy chain. It's worth the coin as the chain stretches out rather quickly from the IP shock loads. 30K and it's sloppy. GM just made the 'slop' acceptable allowing a jaw dropping 0.8" of slop. Run a slop chain like that and watch the exhaust valve tips fatigue from hammering...
How much blowby did the 6.5 have? You are staring at the engine, now, so it's a simple process to replace the rings. Rings are not so much a wear item as overheating causes them to loose tension. No Tension means lots of blowby. Not only do high compression diesels (Ford 7.3, CAT, Etc.) suffer ring damage from going over 210, oh no, GM had to be extra special and crack heads and blocks from running hot. 210 you see mentioned above is the absolute redline you do not want to go over. Really "overhaul" and just do the rings with a cylinder deglaze. Check the cam bearings if you want to look for things, but, how was the summer hot oil pressure? Nothing else should need work and the rod bearings get an inspection when you do the rings.
I love them G~Sheps.
Welcome to thetruckstop.
Thanks for the input. Contacted Leroy and new Bosch injectors are out of stock with no time frame for getting them in.X-2 on going with OE plugs. Or better yet, call Leroy and get a set from him.
I ran marines for a while and towed with them. They were Ok, but always belched a lot more at start-up compared to OE's. After I installed OE plugs from Leroy, the motor was a bit more responsive to throttle inputs.
Neat jacked Samauri. Still original engine, or replaced it a time or five?
Hello,
I'm an experienced wrench but have very little diesel experience. I bought a 2000 Savana 3500 box truck originally gas powered. I also bought a 2001 Savana 6.5 diesel ambulance with no box. I have removed it's cab, removed engine, fuel system, HD 8 leaf rear end and most importantly it's wire harness.
The plan: The box truck's box was modified by the last owner. Insulated, windows added and tinted and a 120V a/c for camping. It came with one loading ramp and I picked up another one so I can drive my "Toys" into it and go camping! I'll post pics soon.
The box van has the box removed, fuel system removed, no drive train and I have swapped the rear end and all suspension components. I am currently putting in the diesel fuel tank. I plan on upgrading the lift pump and harness. I am considering the LEROY kit w/ Carter pump and harness to include the wait to start option.
I would like to make my own harness as $120 seems a bit high for relay plugs switches etc. I need a good diagram if anyone has one,BTW.
Planning on a Duramax clutch fan, 185 thermostat, high flow waterpump, all new injectors and glows. PMD was already relocated. Planning on a 40HP computer upgrade with some additional gauges. Basically the typical bomb proof stuff I see on the net. This truck will haul a good deal of weight in hot climbs.
So I have some questions.
1: The plastic fuel lines are too short and are labled do not repair. Should I just go with metal and rubber fuel lines? Thats what I was planning. if so any recomendations would be helpful.
2: Eliminate the vacuum pump or not? If I eliminate it what is the best way to control the waste gate? Anyone got pics?
Feel free to suggest other helpful mods. Keep in mind cross country towing with heavy loads in the box.
Thanks
Mike
