SplitSsss
Hello,
I'm an experienced wrench but have very little diesel experience. I bought a 2000 Savana 3500 box truck originally gas powered. I also bought a 2001 Savana 6.5 diesel ambulance with no box. I have removed it's cab, removed engine, fuel system, HD 8 leaf rear end and most importantly it's wire harness.
The plan: The box truck's box was modified by the last owner. Insulated, windows added and tinted and a 120V a/c for camping. It came with one loading ramp and I picked up another one so I can drive my "Toys" into it and go camping! I'll post pics soon.
The box van has the box removed, fuel system removed, no drive train and I have swapped the rear end and all suspension components. I am currently putting in the diesel fuel tank. I plan on upgrading the lift pump and harness. I am considering the LEROY kit w/ Carter pump and harness to include the wait to start option.
I would like to make my own harness as $120 seems a bit high for relay plugs switches etc. I need a good diagram if anyone has one,BTW.
Planning on a Duramax clutch fan, 185 thermostat, high flow waterpump, all new injectors and glows. PMD was already relocated. Planning on a 40HP computer upgrade with some additional gauges. Basically the typical bomb proof stuff I see on the net. This truck will haul a good deal of weight in hot climbs.
So I have some questions.
1: The plastic fuel lines are too short and are labled do not repair. Should I just go with metal and rubber fuel lines? Thats what I was planning. if so any recomendations would be helpful.
2: Eliminate the vacuum pump or not? If I eliminate it what is the best way to control the waste gate? Anyone got pics?
Feel free to suggest other helpful mods. Keep in mind cross country towing with heavy loads in the box.
Thanks
Mike
Thanks
Mike
