Detroit Dan
Anyone here heard about the Rustoleum (Tremclad for our brothers to the North) paint process for painting vehicles? I first heard of it a year ago on another site, linked my way onto a a Mopar board and after reading at least 90 pages of information, instructions, positive attempts, naysayers, etc, I decided I wanted to try it. I havent made much progress, bu this is what I have done. I needed to replace a front fender, so I got a used one to practice on. Took me a long time to feel comfortable with the technique, and I put about nine coats on learning. It wasnt necessary to fret so much, because it is much easier than it sounds. My fender came out great. The color doesn't match the 13 year old paint on the rest of the truck, but it looks good and once the whole truck is painted that way, it will all match fine. I just replaced my bed so I am now working on getting some paint on that, as well as two replacement doors. When thats done I'll just have the cab to do.
Quick rundown of what to do if anyone is interested.
4 inch fine-foam roller, Rustoleum (professional seems a little better but regular stops rust works) 100% mineral spirits ( must be 100%, regular thinner doesn't work well). Mix very well, approximately 5:1 ratio. paint is designed to level out, and the mineral spirits help that immensely. Clean up any bodywork, but you don't need it perfect, and you dont need primer. Remember, Rustoleum is designed to stick to metal, rust, bondo, fiberglas, glass, skin, clothes, even cats. So prep is absolutely minimal. Roll out a thin coat, you will see through it its so thin. Dont worry about color coverage yet. let dry 8 hours or more, 2nd coat. When thats dry, wet sand it smooth (-ish) just to knock it down and clean up any runs, dont take all the color off. Repeat paint-dry, paint-dry wetsand. you are supposed to do 6 coats total, wetsanding after every other one. I find it's not necessary to go all six if you arent changing color, but you can modify the routine as you see fit.
After the sixth coat is wetsanded, buff it out. Be careful not to take too much color off buffing, this paint is not as hard as a lacquer or urethane for up to a month. But it ends up super-tough.
