NVW
just to eliminate a thing or 2
did you check for air in the fuel system?
Do you still have the OS filter in there,did you try running it without.
your timing is way out,and boost seems rather high for fast idle no load.
Timing chain ever replaced? How many mls on it?
How many mls on the IP?
IMO,You could have a broke IP shaft
The boost is barometric (MAP), so it's approx. 0.
Try running 2-stroke oil or non det. 30 wt oil in your fuel, at about 1%.
You said it ran smooth with the OS unplugged so it most likely isn't your IP armature, but try slowly revving it to 2000 rpm and holding it there, then slowly bring it down. If you can do that the armature is OK.
