"to old" and its a car hauler (long)
after fueling in Calif near Bakersfield
I hope this is personal use and "Not For Hire". If this is hauling cars commercially in California the owner and driver had better be aware of the Retro-Laws there banning old Diesels for commercial use that do not have a DPF filter, emissions equipment. In other words this old Diesel doesn't belong in CA commercially with few exceptions that may have expired by now.
#1 thing to check on these engines is "Air In Fuel."
Clear return line off IP. Look for bubbles.
What's the fuel pressure at the water drain? Lift pump on via a wire jumper etc.
Lift pump making noise means NOTHING!
The engine WILL NOT RUN on fuel full of air from a kinked hose, clogged tank sock, or intermittent lift pump (bad itself or from a bad Oil Pressure Switch feeding it low voltage/current.) Gasoline Smell or water/bugs are also a problem a clear jar of fuel from the water drain can show you.
Fuel filter is how old? Of course you don't assume anyone knows where or what it is... You are "Starting Over" your troubleshooting.
Is the PMD on it now NEW or did they put the old back on as it didn't fix it?
The ONLY TWO PARTS you EVER throw at these are a PMD and the extension cable. They are so unreliable and flaky backed by Primitive Artificial Stupidity for a Computer/PCM/ECM that has no way to know it failed. Esp with the 'delay warranty claim' timers that don't expire to set a code before the engine is "not running" and the software mode switches to Not Running. The timers allow a flaky connection bothered by a pothole to not cause you trouble as well.
Replace the PMD extension harness with a Made IN USA from LeroyDiesel
glow plug light doesn't stay on wont start , even when warm when they do it starts.
Glow Plug Light.
You are new to Diesels. Cheap parts engine to start learning on. However you need an understanding of WTF Glow Plugs are and how they work, NOW. Bluntly the light IS supposed to go out. You turn the key to RUN without starting the engine. Wait for the Glow Plug Light to go out. The Glow plugs are now hot and will help light the Diesel fuel from HEAT in the pre-combustion chamber. Put Key to start and engine should start immediately. The Glow Plug Light may cycle after the engine is running. If the engine is hot enough there is NO need for Glow Plugs and they WILL NOT TURN ON.
Do not bother cranking over 20-30 seconds. Seriously: the 10HP starter is overheating to ruin and the Glow Plugs have cooled off to USELESS. (Batteries also now HATE you after 30 seconds and are unwilling to give it a full push the next time.) Wait at least 2 min before trying again. A big Battery Booster charger can ruin Glow Plugs. Remove Charger before starting attempts.
There is sometimes a starting procedure of the back of the driver sun visor. RTFM (Owners Manual) also helps here.
DO NOT USE STARTING AIDS. The sticker is a fair warning you can instantly ruin the glow plugs and engine. (Look up Diesel Engine Runaway as one of several ways to kill it. Slowly is bent rods.) IF The fireball coming back out of the intake from working glow plugs doesn't send you to the burn ward.
Video of it's start sequence via YouTube linked here can help.
