Will L.
I serached that out when i added my turbo (centermount) and had to remove my ess/ pol pump drive.
The 2 wire is what you need, not to the 3 wire. It was turns out only 2 wires give one type of signal and 3 wires give th other. You need 4 pulses per crank revolution.
Since yours is all in one oil pump drive, your set.
But just fyi (and others reading innthe future) the crank sensor from the military is 2 wire and ds4 engines used a 3 wire- so all options are covered for anyone wanting to run whatever they need.
Ya know, we like pictures here...
