bhelms22
About 1500 or 2000 miles ago I chainged out my injectors for a set of Bosch from rockauto. Ever since the truck has had a fishbite or hiccup at idle. It only does it when the truck is warmed up. Pulling the coolant sensor brings the idle up and helps some but after it is warm you can still tell a little.
When I changed them I couldnt get the job done so it sat for a week with the return lines pulled and the fuel system drained out. I thought I got all the air out but IDK if there would still be any in the system after so many miles. Just looking for any simple suggestions to try. It runs fine down the road, and I aint got the time to really tear back into it right now.
