Matt Bachand
Depends on the 6.5
Be happy you don't have AC. I lucked out and had valve trouble on the non-turbo side... Seen a set of injector lines on fleabay for 30beans if yours are rough BTW.
My lines look pretty good, hoping to not have to beat em up if at all possible. Geeze there is a lot of crap to pull just to get the valve covers off and I do have AC but it doesn't look like its going to interfere.
What kind of valve issues did you have? Anything similar to this?
Sorry for the delay but I was tied up pretty good with non 6.5 issues over the last couple of weeks but I'm back at it again now.....
96TD or 3500GMC any luck on your ends?
Hmmm, interesting failure. Well I think at least mine is doing good in terms of compression, no pffffft's or smoke. Runs like a champ so far.
Is it just me or do these engines have the quirkiest failures, you can't take anything for granted. Chipped valves, push rods being chewed up in the basepan, runaway, holed pistons, etc. One thing I can say for sure if you've owned a 6.5 for awhile and did your own work on them then I think its safe to say you've seen alot.
