Cylinders and timing set
Since I have to dig for different heads I moved to the cylinders. At first glance they look ok except for #4 and #6. Those 2 have a slight amount of rust near the tops of the bore. The rest had a very slight amount of carbon above where the top ring stops at the top of the bore.
The carbon cleaned off with some lacquer thinner. The light rust cleaned up with a fine wire brush that looks like a tooth brush. All good to go.:thumbsup:
Before I had the timing cover off, I was turning the engine over by hand and thought the timing chain seemed tight yet.[most don't get loose untill 200,000 miles] After I removed the timing cover I found out differently. There was slightly over 1/2" slack in the chain
. Spec is 1/2" allowable slop. Ordered a new Cloyes timing set from Rockauto. I've heard that you only need the chain because the sprockets don't wear. For less than $15 for the sprockets I won't take the chance. The Cloyes sets are much tighter when new than a Melling set was. The one melling set that I used had 1/4" slop when new[half shot out of the box:mad2:]
Caught up to where I'm at today. Timing set showed up yesterday afternoon.
The cylinder pics are in order 1-8
