I'm starting work on reviving a 93 "599" "J" 6.2 engine out of a short bus. I purchaced this engine from a small junkyard 25 miles away for $300.:thumbsup: The bus had 92,000 miles on it and was junked because of 4l80E transmission troubles.
This engine is being set up to replace 92-93 pick-up engines with mechanical fuel injection and a turbocharger.
These engines have a few minor differences from a 6.5 turbo engine. This engine had v-belt accessory drive instead of a single surpentine belt. This ment that all of the accessory drive parts and waterpump and water pump backing plate will have to be swapped from a donor engine. 91-95 6.2 and 6.5 truck engines will have the right parts for use in a truck.Not shure how van engines run the accessorys.
The coolant crossover and oil dipstick were also different and would have to be swapped from a truck. Since this is going in a mechanical fuel injection application the timing cover will not need to be swapped for one with cps provisions.
