RETURN HOSE BETWEEN INJECTORS IS BAD
about 15 years ago a chiropracter told me to tough it out as long as I could and hope a better procedure comes along. Said I'd be flat on my back for 6 months and probably a year before I could do anything. Backs actually gotten better since then
Learn about neutral hip position and controlling your body to constantly maintain it. It is MASSIVE. Usually advanced M.D. D.O. is source. Lifechanger potential.
If 1 or 2 disks is the cause of the problem and the disk is not regenerating, seriously look into the plastic disk replacement. Success rate is amazing, provided the
Disk is proven to be the source of pain and an experienced surgeon.
speaking of return lines, i sprung a leak, on one of the few pieces of rubber hose i have left, yesterday. i use clear hose, not viton, on mine. it fits snug so must be 3/16 size. has to be pushed on with needle nose pliers. i also use it for the boost gauge and the external fuel shutoff valve. some pieces have exposed to diesel for years and have yet to fail.
Clear hose. Another thing I had not thought about using. That stuff seldom fails, been using it on motorcicles for years without a problem.
I need to get to the parts store and get a length of that clear hose for the pump return line and get that on there.
