I want to take mine off but my dad (owner of truck) won't let me![]()
Don't take it off. Just plug it w/ a 2" test plug.:eyebrows:
I now have installed the turbo inlet that is used with the MPI twins, its an aluminum piece that doesnt have the resonator port or the pcv port. I have also built up the outside of this at the 90* and removed inside material for better airflow.![]()
i have removed the resonator on my truck after hearing about a few peoples stories about finding cracks and splits in them and letting unfiltered air into the engine.
after doing this i noticed a bit more tubro whistle and a little better throttle response.
i used a rubber pipe plug from lowes for $2.99
anyone else done this?
lbz most likely wont..... you already have a vvt so you hear it spool up pretty early on. from what i've heard its the lb7 guys who notice it most. we have wastegated turbos w/out the vv technology. removing the resonator allows the turbo sound to be heard a little earlier on. i can pick it up now ~1500 rpm. never used to hear it till it got over ~2k.
