Big T
2nd paragraph^^^Run the RPO codes in the glove box to see if it has the bose system. I think on the older ones there is one wire on the stereo connector that needs power when the stereo is powered up for the amp to work if it has one. The stereo should send the power out from that wire into the harness, works the same for vehicles that had the power antenna. some of the aftermarket adapter plugs don't have that wire pinned in the connector. weirdly I found out that even between the 93 and the 95 I have even though the connectors are the same there were a couple of wires in the connector that were pinned reversed. iirc it was the acc and bat wires but I don't remember for sure. you might need to look up diagram for your burb and make sure the adapter plug is pinned correctly. when I installed stereos in my trucks I had ordered the adapters from the jungle site, both showed to fit a wide range of years but GM seems to like to switch things around and use the same plug, that or it's the bastardized 95 model, a one year only for a lot of things!!
if it's like our trailblazer, I found out that in the front doors the speakers are not normal speakers but subwoofers and the little ones (tweaters) carry the normal sounds. the back speakers are normal but still powered by the amp. one of the subs in the front door is blown and rattles. those in the trailblazer are 2 ohm subs which aren't available aftermarket. only way to get one is through the GM dealer or find a working one in the junk yard or gut the entire system and re-wire it for regular speakers!
