THIS IS A GM 929 BLOCK JUST COMPLETELY REBUILT WITH 18:1 COMPRESSION MAHLE MARINE PISTONS AND RINGS, MAHLE MAIN, ROD AND CAM BEARINGS. HEADS HAVE FRESH VALVE JOB WITH VITON SEALS ON BOTH EXHAUST & INTAKE VALVES, THE INTAKE AND THE EXHAUST PORTS ALL GASKET MATCH PORTED AND INSTALLED WITH ARP HEAD STUDS. NEW AC DELCO GLOW PLUGS. IT HAS THE HIGHEST OUTPUT PRESENTLY MADE FROM STANADYNE DB2831-6282 INJECTION PUMP AND GENUINE 311 BOSCH NOZZLE MARINE INJECTORS, NOT 304 NOZZLE INJECTORS BEING SOLD AS "MARINE" INJECTORS! I CAN INSTALL A REBUILT NEVER USED DS4 INJECTION PUMP IF SOMEONE WANT'S TO GO THAT ROUTE. FOR AN ADDITIONAL FEE I HAVE TWO DIFFERENT TURBO OPTIONS I CAN OFFER ON THIS ENGINE, ONE IS A HOLSET HX 35 WITH A MODIFIED GM INTAKE AND THE OTHER IS A HOLSET SUPER HX 40. I CAN OFFER SHIPPING ALSO. $7500.00
THERE IS A YOU TUBE VIDEO LINK BELOW OF THE ENGINE RUNNING, JUST COPY AND PASTE IT TO YOUR BROWSER TO WATCH.
