3500_6.5
Well, I had the idea of backing the valvetrain bolts off until the valve closed (used the dial indicator and loosened the bolts until it stopped moving and then tightened just a hair so it would be right at the closing point with slight tension) to check clearances that way while I decide how to actually fix the problem. I figured this way will simulate the spacer or shorter pushrod to get me where I need to be. I checked clearances at stock timing marks and everything was good. So I went back the the ~111 degree mark and everything clears there also. I'm thinking to get a rough idea of clearances, I may tighten the bolts down a few thousands at a time and run the valves through a cycle. That should give me an idea of how much clearance I have and then I can figure roughly how much, if any, clearance I will have with the 1.6 rockers. This is all purely for entertainment really, as I will still recheck all clearances once I have the correct parts for the actual install. But it should give me a fairly good idea of what I'm working with.
