NVW
The air bags unload the springs, so the ride isn't more stiff. On my 3500 it is a much nicer ride, without the bags I'm on the overloads.
I have a 2001 2500 hd 4x4 6.0 . What do you need me to measure exactly?
I think he's looking for a measurement on his body style for a comparison.
Ours is a '94 K1500, but I have 2" blocks in the back, so it's not a good candidate to get a measurement for you. I really can't recall if I raised the front or not.
It had the sagging rear look, just like every other one out there. I do believe it's an optical illusion because I think the front wheel well openings are cut higher than the rears. I measured at the frame when we bought it (no blocks), from the ground and it was basically level. It only appears to sag, but I don't prefer the look, so every one I've ever had has gotten a small block in the rear to over come this.
I have about 7 inches rear and 5.75 front. Same size tires.
Does that include the top spring? The lower ones are simple with no need for messing with the bushings. If you're changing the top spring also, then the bushing might be a challenge because even though it's a southern vehicle, the bushing could still be rusted in.Wow, I wonder how mine will look when its the right height?
I talked to a local shop, they had the springs for $ 265/each and install around $ 200. He said if I can get them online for $ 150/each he would install them and include labor/u-bolts for $ 200. That doesn't seem bad for an install price (including hardware), but it might be a job I could tackle myself and save some money... It doesn't seem like it would be too difficult, especially considering its a southern truck and not rusted to pieces.
Any thoughts? Personal experience changing them out?
With the bags on now I would loose the air shock and get some bilstiens. You'll love that ride.
