Sentinelist
Active Member
See signature for why (re: big camper), but I'm hoping to bring them out safely a couple inches. If it's OK for my rig, what brand? Recommendations?
http://www.wheeladapter.com/dually_spacers.php
I would ONLY run the fred's billet steel spacers. Nothing wrong with running them, but I would not use aluminum if you plan on putting alot of weight down on them.
Just got mine mounted up Monday night- talk about beefy! I'm used to working with smaller 20mm spacers for European cars. They certainly feel and look stout, and I'm glad I went with these over aluminum for my load. The rear wheels are damn near perfectly flush and matching with the front wheels in their wells now- I absolutely love the look. But mainly these are intended to provide the widened stance and lower center of gravity to further balance my tall hardside truck camper. The truck drives with even more stability and better handling than before- I could tell it felt better the moment I turned out of my driveway. Imagine the feeling of a dually- it's close to that. I did a quick test drive around town and up to 70mph on the highway with and without the camper and felt no vibrations or loss of confidence- rock solid.
Yeah, these are pretty pricey- I'm still almost balking at what I paid (nearly $400). But if you've got serious loads and a 'skinny' track on the back, these do wonders. And looks awesome to boot. Highly recommended, at least so far- I have not taken the rig off-road, but it'll be light work at that anyway without any serious challenges.
Install tip- they come shipped bolted together, annoyingly torqued up pretty good. You'll need to mount the whole assembly onto one of your hubs to use the studs for leverage, then take a wrench and break out the nuts fastening them together. Smaller nuts work on the same studs. You use your stock wheel nuts on the new spacer's studs. I had to break my wheels off my hubs with a little force and a piece of metal pipe- I used some WD-40 (maybe use something better) afterwards between the hubs and spacers, and then the spacers and wheels, to prevent any future seizing.
