I just changed mine over to amsoil. I added some of the slip lock when I did it just to prevent possible chatter. I recently heard we arent supposed to use the slip lock but I dont have confirmation yet. gonna do the front diff as soon as I get a manual pump to fill it,
I know some guys say you shouldnt change it, but at least check it. There had been a real problem with the differential having only 2 or 3 quarts of fluid from the factory when it should have nearly 4. I changed mine out to Mobil 1 synthetic at 500 miles. The factory stuff stunk and I already had some metal flakes on the magnet/plug.
Highly recommend you change that oil. Both front and rear 75w90 (front), 75w110-75-140 Amsoil, Mobile 1, Royal Purple are all fine in the rear diff. You are probably 1.5 quarts low too. I would change it ASAP.
Hey guys, interested in knowing two things, how does Royal Purple 75w/90 hold up with the G80 rear differential??? Would changing the cover to lets say a MagHytec at the same time be better for the rear end??? I heard you have to put 6-7 quarts for that rear end cover.
So overall Royal Purple is a good differential oil!!!
No additive needed in the G80 locker. Just the synthetic gear oil. And yes, 75W90 front and rear is good. Many of us have been using Mobil 1 75W90 F & R for alot of miles and in multiple trucks.i might have missed it but are we saposed to put slip lock in the rear or not? and from what i read it would be fine o run 75W-90 front and rear?
No it isn't. Did you at least check the rear? They usually came from the factory about 2 qts low (of the 4 needed).After Christmas I'm going to change my Front & Rear diff fluids, I have 50K on my truck now and I've never changed it, which isn't a good thing.
Now you're gonna feel even worse... Aren't you?
Yes, I've checked it. It's dead on, but it's the original....
