FellowTraveler
Great info FERM, I'll factor thickness to see if there is much difference if not I'll use that condenser you suggested as it is a direct fit. Again thanks!
My condenser is 16" x 35" or 560 sq " Its the newer block type, I had the proper fittings welded in like the old condenser had. I had to make a couple custom hoses to. The orifice tube go's right into the evap.
Did the math; about 566 square inches frontal however it's .63" thick so minus .37" of 566 sq in = 209.42 square inches so that unit has 356.58 actual square inches of cooling surface.http://www.jcwhitney.com/p3088421/sku-8739585.jcwx
Cant remember where I bought mine, this was at the top of google search.
It fits my truck real nice and I'll be able to use stock mounts.
I seem to remember rear HVAC on medium or high prevented evaporator from freezing.Perhaps this is moderately related and maybe not. Years ago - maybe close to 15 years - I got some advice from a guy on a Chevy 4x4 forum that said to always run the rear fan on medium or higher when the rear A/C was on. I can't recall the problem he said it would create if we did not, but we've always done this since we've had our '94 and we've never had an issue with the rear system. We always control all HVAC from the driver seat. Always.
Related?
Related?
Whenever the A/C is on, the rear fan NEEDS to be on to prevent liquid slugging of the compressor, and starving it of oil. The problem was with the rear TXV used up till 95 would completely close off when the rear fan was off. This would allow liquid refrigerant to collect in the high pressure line to the rear A/C, and with it oil would collect. After long enough, the high side line to the rear could collect enough oil in it to starve the compressor of oil, and cause compressor failure. Starting in 96 GM used a different TXV for the rear A/C that would never completely close off to help reduce the amount of oil that could collect in the rear line. Also by not running the rear fan, the rear system will get cold enough to pull enough charge out of the system to make the compressor rapid cycle like it would when it is low on charge making the front air get warm. I pretty much always run my rear fan on low, and my front one on 2. I can hang meat inside the cab on a 95 degree day once it stabilizes the temp inside. I RARELY turn my front fan above 2, or put the rear on medium, just don't need to.
GM didn't put an accumualtor in the rear line because all of that 5/8" ID tubing from the rear to the front acts as an accumulator, so it isn't needed. All an accumulator is is a storage vessel for liquid refrigerant as to prevent liquid from making it to the compressor when the system pulls down and doesn't get enough heat in it to boil off all the liquid before it exits the evaporator.This condition is also described in post #1 as the sensor for the TXV being loose from the evaporator pipe. However, I agree with FERM's answer. Adding to it the lack of a accumulator for the rear is why a liquid slugging condition can exist. The real solution to slugging would have been to join the suction lines Before the accumulator or feed both evaporator lines into a single accumulator.
