snoman699
diesel newbie
I'm not sure if this has been posted before, but here goes...
As part of cleaning the rad, I decided that the factory setup for the radiator drain suks. It drains into the rad cradle and piddles all across the front of the truck.
So, I decided its time to make a proper drain:
1. Drill a 1" hole into rad cradle just below the radiator drain
2. Add a hose onto the drain spout. (5/8" I think)
3. re-install rad.
Here's the results:
Its that easy. (if the rad is out!)
Cheers.
3. re-install rad.
Here's the results:
Cheers.
