Husker6.5
IIRC it was in a masey ferguson on a 6.2
Good memory for both of us, 6.5 in a Massey-Ferguson: http://youtu.be/FwFWNReCmck
That's what it was that Tim told me...I was looking at that video and saw the two pumps on that tractor driven by a belt and that got me wondering again...so... Could the cp3 pump through a shell of a larger style stanadyne to time the injection events and let the cp3 supply all the necessary fuel and pressure?cp3 uses electronically actuated injectors.
I would be interested to see a boost controlled mechanism that can do this mechanically with climbing levels of boost. I have seen this done in bosch pumps, but because of the design, I am interested in seeing if this can indeed be done with with a stanadyne.
That's right, I was thinking of his LSR. I have no idea what was on the drag truck.didn't he have a drag truck as well as the LSR?
Apples to Oranges. Drag truck was a gasser. It's getting the old LSR motor though as he is preplacing it with the P-400.
Paul
There was a 6.2. Diesel drag racerback in the day had a highly modified mech Ip on it not a Gm one IIRC from a Navstar Diesel I think. Bill has told me before I just don't remember.
Strictly drag machine 14:1 CR I think said it took forever to warm up enough to make runs 15 minute pre warm ups.
The DB2 pump is not a good pump for all out fuel, it just doesnt have the plunger volume to supply the fuel reliably in the amount of time given during the injection cycle...
The DB4 is the only pump worth considering if you want real fuel reliably... I started with a DB2, but for the cost it takes to have the work done, its more sensable to order a DB4 rotor.
Right now, the peak fueling we have with a DB4 is just about 185cc's, with NMB2's pump being a little generous at 205cc's (Albeit low, tapering off at the upper end)...
The DB pumps by design cant have the restrictive parts opened without fouling up the whole works... Any work to overcome the former results in to much cost in R&D and fab... its just not worth it... Until somebody comes out with a bolt on replacement for the DB pump, we are stuck at about 180cc's... That being said... 180cc's is enough IMHO...
