Goose57
Hi all anybody know where I can find a pump bracket 15589748. can not find it anywhere
Thanks d I’ve found it still hooked to the old pump in the drain pan under benchI just seen this and was thinking that most of the GM truck of this era used the same PS bracket or mounting location where you might be able to make a bracket off a gasser work. any pick a part junk yard out in your area?
Thanks WillIf you buy one for a hummer- 95 or older. The 96 and newer uses the van intake manifold and I think the return line os different.
What exactly is the quadstar return line kit?Working on a couple of issues on my build. Anyone ever had one of these oil pump drives apart? Going to use this one for an oil priming tool for these engines. I was going to grind the cam gear down but didn’t want to jam metal shaving in between the gear and housing. Also anybody have a diagrams or pic,s of all the little clips, hangers and straps for these engines. I did invest in the red GMT/95-CK-1 but not enough detail. Do I need to get the GMT/95-CK2 also? I wish I would of labeled more or took more pic,s while disassembling. Any one using the Quadstar fuel return line kit? I don’t like using the rubber line included, laying down on the block. I might modify the 5/16” steel line with a brass cross fitting at the rear. Don’t use a cheap engine stand The more parts I put on the more it dropped.View attachment 84132View attachment 84134View attachment 84135View attachment 84136
Ok. I was thinking injector installation kit
