treegump
Romans 3:22-24
For starters, got my south bend clutch installed and thought YES!! I HAVE MY TRUCK BACK!! Then I started smelling fuel and then the motor started shutting off randomly, and a few of those times I had to wait a bit to get it restarted. Just checked a few minutes ago and it'll crank, and fuel will come out the fuel filter manager, but it won't fire.
-1996
-K2500
-Standard
-205k
-relocated and another PMD (bought it off a supporter, but can't remember if the PMD was new...), injectors, glow plugs, FSOS, FTB, new OPS (which seems to be showing high since replacing it...), I'm sure there are others, just can't think of them
-"F" Turbo, no EGR
-Currently 30
-Power Service
-Merrillville, IN
- Air filter __< 100 miles ago_______
- Fuel filter __< 100 miles ago_______
- CDR Valve? ___~30k miles ago______
- Coolant – last flushed/replaced at ___<10k miles__________
- Oil – synthetic/regular, changed at __<7k (probably only 4k...but can't remember) & regular
- Batteries – state of charge, (matched set) replaced at _<10 miles____________
- Battery cables and grounds (removed, cleaned and tightened): I believe they are all cleaned & etc
- Glow Plugs - how many miles on them? _~30k (maybe??)____ What type? __**60 (the ones that automatically shut off - been a while)__
- Injectors - last changed at ___~30k____________
- What were you doing when it happened? _Driving home - would only stall if idling or slowing down_____________
- How was the truck running fine before this problem appeared? _Running wonderfully___
- Has this problem ever happened before? __Not full turn off - did have some stalling/loss of power, but was still random___
- Describe any related factors that might be part of the problem. _I've never dropped the tank and check the fuel sock filter, cold weather, been sitting a while (but I ran through a tank of fuel after putting the new clutch in before it really started failing. Leaking fuel from fuel filter manager, heavy hits to the front when a skidsteer pulled me from a hole (maybe damaged PMD)__
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _N (Check engine light never came on when it stalled)___ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? _not now________
1b] Does the engine crank over? ___yes_____
1c] Are your batteries fully charged? __yes_______
1d] Have you removed, cleaned, and tightened all battery connections? _no - engine cranks and did all the connections when I replaced the batteries_______
1e] Does your Wait to Start light come on for a time? How long? _normal - 5 clicks & 30 sec or something like that________
1f] Does your glow plug light come on? __Yes - same as the Wait to start...isn't it?_______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? _No smoke noticed_______
1h] Does the Service Engine Light Glow during Start/bulb check? __Yes______
2a] Can you hear your lift pump working? __Yes__________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _(not sure - but was shooting 1-2' in the air from the fuel filter cap________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
(will check 2c-2e when I get a chance)
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _front bumper__________
3b] Condition of Extension harness (if used) Vendor or Homemade? __Vendor_______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. __Good, I believe_______
3d] PMD Make: ___________(Gotta check)
3e] PMD Age: _____________(Gotta check - but thinking <30k miles)
4] Stalling Issues
4a] Do you experience stalling only when hot? __Was, but has gotten worse_________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _Deceleration & Idle_____
4c] Does pouring cool water over the IP seem to help with restarting? ___Didn't try it______
4d] Is stalling momentary (engine recovers)? __Used to be, but not any more_______
4e] Does SES light come on when engine hiccups? __Didn't notice it_______
4f] Does cruise control quit working when engine hiccups? __N/A_________
4g] Does re-starting seem to reset engine, restoring cruise and power? _N/A________
4h] Changes to dash lights or instruments during stalling events? _N/A__________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _?______
5b] Any bubbles or oil film in coolant overflow tank? _No______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __No________
5d] Excessive white smoke from exhaust on cold start? __No_______
5e] Excessive black smoke from exhaust under hard acceleration? __No________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? __Boost & EGT_________
6b] Maximum boost under load? __0-12__________
6c] Have you added a performance PCM (reflash) or Chip? _____No_________
6d] Have you changed exhaust / downpipe / crossover? ______Yes__________
6e] Wastegate – mechanical or vacuum (OEM)? ___Mechanical___________
7a] Single or dual thermostats? __Single__________
7b] Have you replaced them lately? Manufacturer of replacements? _<30k________
7c] Have you pulled and cleaned Radiator and coolers lately? __Not recently__________
7d] Have you replaced the fan clutch? Manufacturer of replacement? _Can't remember_______
7e] (winter) Have you tested your antifreeze? Good to what temp? _Not recently, but seems like it was good for something like -50, haha_________
7f] (winter) Are you using a winter grille cover? ___No________
FFM is leaking. Drippage at heater (which is new) and then with pedal to floor, its leaking at sealing ring of the filter itself. FFM is also relocated to side of intake manifold.
Truck would randomly shut off while driving home. Though it might be the FSOS since I was leaking fuel on top of the block. Removed the intake manifold, replaced the FSOS & OPS, did the FTB mod & relocated to side of the instake manifold. Since then its still leaking, and the truck shut down randomly twice on the test drive of getting everything together. I went out today to get it started, and it wouldn't even fire. Just cranked...
-1996
-K2500
-Standard
-205k
-"F" Turbo, no EGR
-Currently 30
-Power Service
-Merrillville, IN
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
