Turbine Doc
Just Another Diesel Guy
doesn't take much of an air compressor, even one of those cigarette lighter emergency tire inflator pumps will work.
Go to auto part store, for about $20-25 get a diagnostic vac/pressure gauge, and 6' or so of rubber vacuum line, then you can snake the hose into the cab with gauge installed, and test under load, idle check is okay, but proof in the pudding as it were, is a road test, see if 3-4 psi is being sustained when cruising, and not dropping below 1 psi on hard acceleration or if it does dip, that it doesn't dip below for very long, 5-10 sec max, and should recover back to 3-4 psi once you have achieved the desired cruising speed after the hard acceleration.
