speedbird1229
Hi,
I'm new to this forum so Hello to all of you guys for the first time and I'm here from Estonia, Eastern Europe. My girlfriend is also an American cars fan and we got a 1985 K5 Blazer 6.2 Diesel for her in the beginning of this year. We have done quite a lot of work to this truck because it was in pretty untouched shape and maintained OK in Sweden for most of its lifetime but had been left forgotten for years before we finally bought it.
I have done gasoline engines most of the time and didn't know much about diesels. Now I've learned quite a bit with this 6.2 and I must say I love this engine because it's just such a nice classic diesel. I love the sound and the behaviour of it
Suddenly our Blazer just stalled and wouldn't run at all. It lost its power and we thought the injection pump is gone. Fortunately I found someone who was able to diagnose it must be the check valve or something clogging the return line. He was right - I removed the check valve from the pump and the glass ball was totally stuck. I was able to loosen it a bit but that original valve never really worked anymore. I got a used valve from a guy here and the glass ball was moving very well when I got it. The truck drove for about a week of daily usage and then lost its power again. I found that the other valve also got stuck and I spent quite a bit of time trying to loosen it. A lot of brake cleaner and WD-40 helped and I was able to get the truck running. A few more days of nicely running engine and again, the same issue! I found the valve to be stuck last night, cleaned it the same way and got it working again.
Is there some dirt getting out from the injection pump that disables the valve? I really don't want to remove the pump because it's quite a bit of work and otherwise the engine seems working really OK and I cannot find any dirt from the outlet of the injection pump where the check valve goes into.
I have a fuel filter installed right after the fuel tank before the optional electrical fuel pump and I ofcourse also use the GM original fuel filter under the hood which we replaced quite recently with an AC Delco filter.
Now I'm thinking that I should go to a hydraulics store and get some parts to make it possible to add a separate filter to the outlet of the injection pump before the check valve. I have a brand new check valve ready which I ordered some time ago from a military shop in eBay.
By the way, can such kind of check valves also be used on this 6.2 engine? http://www.ebay.com/itm/Fuel-Non-Re...es_EngineParts_SM&hash=item53ef11acab&vxp=mtr I guess we should know the pressure it holds...
