pressure plate and flywheel bolts
I 've got the cracked weld issue but I think alot f it is the slop in the pin that holds the shout on. The pin is half the size of the hole. is yours like that too?
Yes it is. After welding up the cracked welds the slop was at least cut in 1/2. It's much better than it was before. also make sure the roll pins are all the way in. I put a hose clamp around the shifter tower after i tapped the roll pins back in. That also dropped the shifter slop down.
