JMJNet
Recruit
Yes, the only line that you can take out just by taking out the clamp. If you trace it, that line does go to the PS reservoir.
I found this site to flush fluid.
Called GM about possible recall that AcessnEights had, but no luck.
The Stealer told me I should try flushing the fluid first, since I'd have to do it again anyhow with a new pump, and all i would be doing is makign sure the rest of lines are clean.
Good idea.
I found this thread. http://www.dieselplace.com/forum/showthread.php?t=137081&highlight=power+steering
Is there an easy way to verify which line is the return (low pressure?)
It must be same spot as link, with the rubber hose and a one use clamp on it? I'll take pix in a minute when camera charged.
Once I remove that one use clamp, i just put a regular hose clamp there I assume?
Yep.
Leroy, how you making out on those SS lines?
What am i looking at for cost and how difficult of a job is this?
I kinda like powersteering and power brakes, so I'll probably get right on this now.
While I had the vehicle jacked up I checked all ball joints and wheel bearings and steering components.
I've had this truck for 4 years and 35,000 miles. My Ball joints and wheel bearings have always been tight as a rock... Shows good greasing habbits go a long way.
I had to replace pitman arm, P.s. inner/outer tierod (only outer was bad, but did both and new sleeve at same time).
Not too bad considering this poor beast hangs a plow on it that weighs over 1k.
If your like me I had to relearn how to check ball joints going from solid axle to ifs. You have to support the a-arm and put the vehicle weight on the lower a-arm to get an accurate check of ball joints. I kept thinking mine were tight until I discovered this. Maybe I'm just slow.![]()
I have not had one of these apart yet, but if you have the res of the pump then it is just an empty tank right? if yes hose it down and dry it out.
My brother is researching a rebuild kit for our pumps. We are going to try one and see how we like it. Should be about $35. for the rebuild kit
