OK, I will get a price and let everyone know what it will be. Should be on Monday.
Here are some of my Chevelle. I got the Fittings from Areroquip. On the return line of the HB unit I used a compression fitting.
Very nice! Exactly the hose/fitting set-up I'm hoping for... Thanks for the pic's.
Because the pump is slowly getting weaker and noisier, I want to get this done soon. So I went and ordered a pump from the supplier I usually deal with. The pump came in the next day, I forked out the $250.00 and took it back to the shop at work. It may be the right pump but it's definitely not the right reservoir. This one has the small round can type with no capacity and no fill cap. The dealer showed me the part numbers and what all and insisted it was the right one. So maybe it's the right box but no way on the unit.
Hopefully I'll get this sorted out tomorrow.
I was thinking, do you think you got a pump for a 92-95 style?
I don't know. The parts guy came out and looked at the pump in my truck and is going to resolve it. We both think it's the wrong pump in the right box. I'll know in the next couple days. It may be the pump for the 6.5 Van. That apparently is rigged with a remote reservoir. It is likely the right pump but with the wrong reservoir type. It's definitely not what I want.
Howdy Leroy.
I'm always complaining about my Power steering that I found a bit weak compared to the 97+ trucks.
I was told that the 97+ use high output PS pump, so the the solution would be to swap to this HO PS pump.
I believe you have to reinforce lines and plumbings too to achieve such a swap.
Your next kit ?
Check out autozone's website, there is a replacement H/O power steering pump. More pressure, higher flo it says. Shiny too, no resevoir.
