No if bad it will not necessarily leak, could be an internal leak or someone forgot a part when assembling it.Well I still have to almost stand on the brake pedal to stop. I'm assuming if the new booster was "bad" wouldn't there be a leak of some sort? Also could I possibly need to go through the whole brake system and bleed that as well?
Is there a visual way to check the one that on it for the right info? Looking at parts on napas site doesn't really help much. And orielys where a got the booster doesn't even list a jd7 master cylinder just JB6.
That is the VOV valve for the mall parking feature it must be switched over or eliminated w/GM kit or use older model high pressure p/s steering hose assembly.the new power steering pumps im seeing say they dont come with the electronic parts. I noticed on mine theres a plug on the bottom of it, is this something I would need to remove from mine and put on the new one? would a1 cardone be good or should i go with something different?
Will hits the nail squarely on the head and drives it home too. I've seen small important parts installed backwards and even missing on some rebuilt units "this is why I rebuild my own hydroboost units always" took me awhile to get all the GM tools and now in my tool collection.IMO You have a bad booster or the wrong booster. Possible the PS pump has failed esp. that goofy electric valve. Brakes on the floor is the steering wheel hard to turn? I would start over and re-check the entire brake system including beading it out and adjusting the rear shoes. The proportioning valve can go bad and you loose rear brakes.
If you have foam in the PS oil tank you don't have all the air out. Wait 30 min for the foam and bubbles to disperse between beading attempts.
Get a NEW virgin PS pump. Keep your old spring from the relief valve in the PS pump as hydroboost systems are different tension. Yes spend the money on NEW!!! Otherwise go to a junkyard and get a good looking used PS pump from a wreck. Trust me you will have better luck. a1 cardone lasts about 30 min before the "broken" junk they "patched" fails and dusted the entire system requiring flushing the PS cooler, line replacement, steering box replacement, hydro booster replacement, and of course another PS pump. The bitch bolt on the middle of the block is matched by the starter rear bracket bolt as the two worst on the truck to mess with.
I have had several bad a1 cardone units out of the box that don't even work. Their filter assembly offered as a upgrade in the PS pump is a fing joke. So New parts don't mean good parts. After going through 5 junk A1 Crapdone units I have a bad hard on for their no-quality reman krap! Get everything working and their fing box blows a seal 6 months later and runs the pump out of oil. 3 pumps later and 1 box it is working again.
I suggest and use these filters on the box return line. Beware of knock offs. Flush the old PS fluid out of the system as it is wearing things out now...
http://magnefinefilters.com/
