DieselDonutz
Hi Everybody!! it has been a few months since I have been on here. I have been working steady on my truck. last time I was here I was looking for help with my truck ( had just bought it at the time). it had an issue when after it warmed up and not just operating tempature but running for 30min or so, or if I got on it a little, or tried to pull something, it seemed to lose power. it suffered from slow take off, and it had trouble maintaining 65 to 70 on the highway. the engine seemed labored. and also the end of the peddle seemed to cause it to bog. started great, didnt seem to miss at all. didnt stall. It turned out it had a blown head gasket. I since then put brand new heads on it, replaced the injectors, glowplugs, pmd, turbo (hx40ii) added a custom cold air intake, replaced the exhaust with a 4" turbo back, added boost, egt, and fuel pressure gauges, and added a second liftpump. well guess what, I still have the same issue. I am at my wits end. I dont know where else to look. the truck seems to run a little bit better as now it can hold 70 mph unloaded but still bogs at wot and still suffers from slow take off and labored engine at times. sometimes it seems to run well but any time I put it under load it seems to provoke this issue. I get no codes. egt are 300 degrees during normal driving, boost is set to 10 psi (currently) and fuel pressure fluctuates between 10 psi to 5 psi at wot. I have changed out the pmd with 3 different ones with no change. I have in my sig, that I upgraded the ecm with a new heath diesel but it hasnt been installed yet since it is on its way in the mail. I am hoping maybe on a chance that the current ecm may be bad but I am feeling pretty depressed at this point and am thinking that is not the issue. I am really stuck at this point and could really use the help of some seasoned 6.5 diesel owners out there. has anyone got any advice that might shed some light on an area that I havent checked into yet. If so please I am at you mercy!!
