Danish Farmer
My Silverado 1995 needs long cranking before starting up, and during acceleration it is lacking power, and stalls lightly, until the throttle is raised. It usually does not stall totally. Problem has gotten worser in a month, and here is what I have done so far.
-New fuel filter + cleaned the little filter screen in FFM
-Tigthned clamps on fuel lines under the FFM
-Replaced glows
-Injector cleaner in fueltank
-New PMD (Stanadyne on intake with heat zink)
-Cleaned four grounds so far
-Checked connections on OPS (looked good) Guage works, Power on orange vire.
-Checked fuses
-Now running the LP constantly with a bypass-wire
(LP Sounds loud the first seconds when been sitting for 15 minutes or more, and I seem to be able to bleed a little air from FFM every hour of sitting) -and IP sounds a little harder (Knucking) at idling when first started up.
I got a good stream of fuel on the FFM bleed valve ideling, and a stream from the t-valve.
No fuel leaks on the floor but some "sweat" arround some fuel lines under FFM
Engine RPM tends to switch rapidly between 900 and 600 a couple of times every time I move my foot from the trottle, going on the road.
Truck has been siting for two years at the former ovner, but ran ok for a week.
Folks, please help me being a new Silverado-ovner in a country with almost no US trucks.
Great forum, and thank you
Max Madsen from Denmark
-Replaced glows
-Checked fuses
