JayTheCPA
Sure, it is great to daydream and think ahead
The exercise part is looking more like getting a dozer just to have one. Sure it is cool to have the thing, but without an ongoing need to use it, the hunk of metal turns into a maintenance hog as it is one more mechanism that needs attention in order to keep it reliable.
With that, freely admit that I bought one of my vehicles with the intent that it could provide power if necessary as I wanted to avoid the money outlay for a generator. Figured that since I already had a 30Amp / 120V inverter, why not use the truck's dual alternators for limited back-up power. And as detailed above, it did. Once. Have since moved-on to generator power as it is far less expensive to get 30Amp / 240V out of a portable generator than out of a 12v battery bank
I do still have the 30 Amp / 120V inverter lying around as it costs me nothing to maintain or store, but the generator will come out of the shed first rather than reflexively hook the inverter up to the truck.
So, for all those what-if's, scope the solution to the situation. Using the vehicle for power generation is a crude application and will lead to increased maintenance on the truck. Another thing to note is that diesels do not like to run without some load. I know of some corporate diesel generators (whole building size units) that were not happy as they did not have enough load and required extra maintenance.
To the daydreaming part, if the scenario is remote off-grid working, chances are good that four lithium batteries (Group 29 size equivalent), an inverter, a properly sized solar array, and a 2kW inverter (for backup purposes) will do the job. In this scenario, power loads are relatively light. Actually, chances are good that even the electronics are able to tap directly into the DC power with DC to DC converters which could eliminate the inverter. Even hot water creation is not a huge factor as there are solar units available. I would use the truck to fetch food and fuel for the generator.
If the goal is to run enough construction equipment to build a neighborhood, I'd get a properly sized generator. In that case, the truck would probably need an in-bed fuel transfer tank to supply the generator.
Notice how using the pickup is now among the last things I'd put into service for power generation
In a commercial application such as powerline repair after storm damage, having a vehicle with PTO power generation might make sense. But then again chainsaws are still using gas and the boom needs PTO driven hydraulic power, so not much need for that PTO generator.
