Turbine Doc
Just Another Diesel Guy
99.5 is the belt that works on both my 98's when I pulled the vac pump, 100" was too loose in a day, too much stretch, 99.5" tight at 1st, but after about 2-3 days in middle of optimal tensioner zone.
My 96 has been making a racket for awhile now and my question is can the tensioner make alot of noise if its out of adjustment?
I dont know but Ill thorw in the my AC pump did before it went
What kind of racket is it making?
Fan clutch maybe??
Update:
Bought the 99" belt and it is at the very top of the adjustment on the tensioner. It was freezing outside and I ended up having to put the belt in the dryer for a couple minutes. It went right on after it was warmed up and flexible. Anyway, no miles on it yet and I think it will break in to the middle of the adjustment on the tensioner. I would def recomend this size over the 100" if you remove the vac pump. Here is how the tensioner looks now.
