Dave Barbieri
What if....As far as the tron stuff you can handle it, these aren't as sophisticated as one would think just invest a little time you'll git er done, you see what passes for a tech at GM stealerships these days
Ya know, the mechanical accelerator pedal is basically just a rod with a pivot point in the middle. One end has a pivot point for the pedal itself, the other end has an attachment point for the accelerator cable. Sort of like a vertical see-saw. Why not cut off the upper end of the mechanical pedal assembly just above the pivot point and attach it (braze/MIG/whatever) to our existing APP? The 'puter gets its info as usual for trans control, etc, and the pump gets a mechanical 'tug'. Since all this occurs at the same time, I'm thinking there'd be no noticeable difference. :agreed:
Now, because the IP is disconnected from the system, you'd probably get a SES warning light, but that's easy to deal with. And, there's be no cruise control. But that, too is pretty straightforward - just install an aftermarket off-the-shelf unit. :thumbsup:
