KrisML
OK so the engine I had rebuilt for my truck had suffered a gasket/sealant failure and flooded the oil pan with coolant. Engine had at most 50 minutes of run time. So when I pulled it apart I was hoping to be able to just change all bearings and of course gaskets and be on my merry way. Now obviously I had to disassemble everything to clean it. I even pulled the lifters apart to get any oil residue out of them.
Since they were new I was hoping to reuse the piston rings as the never had time to fully seat. While pulling the pistons apart to clean them one broke. ONE! All the others came off fine. The place I ordered bearings said they can only get a full set of rings, all 8 cylinders. I've looked some but it's looking like I may be stuck buying a whole new set. Which if I have to I will, but I'd like to not if I can for money reasons.
So I was wondering if anyone knew of a place that would sell a set for just one piston? It's for a 6.2 bored .020 over.
I figured it would get more looks in the 6.5 area.
Thanks
Kris
Thanks
Kris
