schiker
I searched my helm manual and did not see a spec or that special tool listed in the transmission or clutch replacement sections. I could not find a spec on Alldatadiy either. Both just mention installing the pilot bearing.
From the picture on ebay of that special tool it appears it would stick out of the crank by the depth of the chamfer on the id of the guiding diameter of the "squaring block or guide bushing". I am guessing its about 0.060 x 45 deg chamfer which is a typical call out on a print. So that would increase my input shaft penetration depth into the bearing by about 1/8" so I was probably on the right track. From my measurements I might let it stick a bit more than 0.060 and hope my eyeball was pretty close on measuring the depth I set the bronze bushing at last time. It appears I have a bit of clearance to play with.
The transmission shop said LuK did not have a spec for pilot depth. I guess next I'll try and google for that tool and go back to alldatadiy and search that tool number. Maybe just maybe I can find a drawing or gleam some info from somewhere.
Thanks.
Thanks.
