buddy
Active Member
polarized capacitors have stripes too. If you just have an ohm meter and check the ohms across the line and resistance climbs for a while then its a capacitor.
Diodes are typically used for voltage regulation. The PCM regulates this voltage to 5VDC. Capacitors are used as close to an IC as possible on a power source to clean it up.
I believe it is there to provide as clean of a reference as possible for the high resolution timing source within the Optical Sensor. A small variation in the reference voltage would offset the feedback to the PCM.
Although if it were a diode you would only get an ohm readiing through it one way. And could be used to shunt voltage spikes to protect the PCM as JiFaire says. A diode alone is not a good way to protect a circuit, but maybe there are some tiny resistors on there too?
