I have one, and were it gasoline I'd be worried, but with Diesel flash risk is pretty low, I mounted mine in the tee I put at outlet of my filter mgr whenI did FTB, used copper tube vs. nylon, if it sprins a leak in the short run that is in the cab or gage leaks, I have a cap I can put on the tee. Mine is mounted for now next to steering wheel in plastic trim section just below dash gage trim bezel may go to gauge pilar, or dash itself 1 day, you will want to monitor supply to the IP, tee into the hose at IP inlet, or if you do a FTB mod, in the outlet of filter mgr as I did.
I assembled this from parts laying around the garage. I think I'll hook it directly to the IP and leave it under the hood in a Ziploc and taped to the fender though a bracketed mounted to the hood is a consideration as well. I'm mildly curious if that valve is going to weep if not fully closed or fully open.
Thoughts? Anyone.
Wouldn't be a problem. Turbine Doc did this with his FTB mod. Fitting is at the filter manager. Couldn't find a pic on this site but if you go back to the old site and search for "feeding the beast" with titles only checked, there is a pic in post 2.
Yes I have (2), one at my Racor as well as the filter mgr with red LED for each to let me know which filter is the culprit.
I was hijacking your thread to clear something up. The idiot light is to tell you when your filter is clogged. You start sucking a vacuum. With that switch when vacuum reaches 7psi the light comes on.
Well, would need a pressure switch then, switches at <4 or 5 psi then?
