chevyCowboy
thanks for clearing that up iv searched and never really found any thing
Dragogt
The precup (located in the head) is the actual combustion chamber.
The injector, glow plug are in this little chamber and this is where it all begins.
As the piston approaches TDC the air in the cylinder is forced into the precup through the little slot that connects to the cylinder.
The angle of the slot in the precup starts the air swirling around inside the cup and then the fuel is injected and combustion begins.
The hot gases build pressure and then exit the pecup into the cylinder.
The little indents in the top of the piston direct the outfloe from the precup into two swirling masses of burning fuel and this causes more mising with available oxygen in the cylinder.
Here is a pix of SOME of the different cups used.
The concept of the precup is to provide a cozy little place for combustion to start and to help the mixing of air and fuel.
The Precup design has been around for a long time. Caterpiller used the precup in diesels back into the late 30's and continued its use way up and even into the 70's
Emmision regs and advancements in design eventually forced the precup design out.
Engines like the Cummins 5.9 have the combustion chamber in the piston top.
The precup has many advantages but also is a slightly dirtier engine (emissions)
The precups in the 6.2/6.5 morphed a lot over the years of production.
The early 6.2's had a very tiny port in them and as time went by the port changed sizes and shapes many times with various little marking being stamped into the cups to identify them.
The late 6.5 TD cups have a diamond stamp on them.
These had the largest size port ever used in a prduction 6.5
As a rule of thumb the smaller ports give higher velocity and better fuel economy than the large ports.
Early 6.2's in K Blazers could be counted on if driven right to deliver 24 MPG Highway with ease.
This was due to in part to the precup design and the fuel delivery settings.
The J series 6.2's of the later 80's had a much larger port in the cup plus a higher fuel setting. They produced more power but at a reduction in MPG's
The 6.5 saw several incarnations of the precup. The N/A version had two common sized ports and the Turbo Charged models saw at least three changes. The most common being the Cups stamped with a "T" and also the one with the "Diamond"
The "T" Port was used in the 92-93 engines and the 94 and later usually had the diamond BUTTTTTTTTT there was always the odd duck.
Now then there is Military stuff, All bets are off here. These critters had a variety of stuff that in many cases was peculiar to the MIL stuff (Just like Injection pumps)
The precups can be swapped back and forth to get just what you want.
The only things is that all the cups have to be the same.
I have pulled engines down that have had two different sets of cups. (heads swapped)
This is a bad thing as it changes the running characteristics of each bank of cylinders.
I have even seen two or three deifferent cups in one head. OMG what were they thinking????????//
The biggy is to be sure the cups are matched (same markings) and they they sit flush to no more than about .003" above the head surface. (Never lower than the surface)
Some aftermarket cups will fit GM heads and some wont.
Some shops surface heads with the cups left in place. This is a bad plan. The cups should be machined afterwards to fit correctly. (Takes a special jig)
The aftermarket heads I have seen come with the precups pressed in and the heads ground afterwards to assure a good finish ?????????/
I have used Clearwater heads and they work fine. (these had the cups and heads finished at the same time)
I used the "T" cups in my DaHooooley build this summer.
Not because of anything special, but because I found them for a right price (free) and they were not cracked all the rat poop like my diamind cups were.
The ports get very hot and they will crack at the mouth. The cracks will propagate outward and if they get over 3/16" long the cup is junk.
If the crack crosses the fire ring on the gasket it will eventually cause the gasket to fail.
Hope this is useful
MGW
Yes the diamond was and is the last incarnation.
Even the aftermarket stuff from Clearwater is marked with a Diamond. Now this said the aftermarket stuff is different. The factory cups are non magnetic and the aftermarkets will see a magnet stick them.
The port size seems to be the same though. The interior shape is also different on many of these cups too.
I used the "T" cups because I got a set FREE from a used set of heads.
The difference is very slight and will likely make zippo difference is power output
MGW
I try to leave materials that are useful and helps others.
MGW
I think that is what I said, The stock stuff is NON Magnetic and the afternarket will stick to a magnet.
Its early, I know he he he
I have used heads from Clearwater and had great luck.
Ratman has a set on his truck, same feelings.
Their service was great and the price was even better.
What bothered you with these guys??? Curious I am.
One of the other folks that comes here works for a shop that services the little delivery chip trucks and they buy the clearwater heads many sets at a time and have had great service from them
MGW
there's someone one ebay selling blocks that are cast and machined in canada might check with them.
Cams have been explored, been found to be low bang for buck if at all improvements, I spent some quality time at a dyno meet with Dennis Garmon http://www.garmonsdieselperformance.com/ one of *THE GUYS* in Diesel performance world I asked his opinion on it, he recommended that there are better ways of going for power, cams were not on his list of things he likes to do to a performance Diesels, that was March 2005, maybe he's changed thought on it, but I doubt it he was pretty convinced at the time it was more or less a waste of $$$
Turbine Doc, I mostly agree with your statement as it applies to stock manifolded engines. But, in an engine where other options of making power have already been exhausted, and someone is trying to get that little extra edge, there is room for improvement.
I wouldn't take anything from many "performance shops" too seriously, as they consider the 6.5 diesel a waste of money, you WILL get laughed at. So how can they justify all the time it takes to properly design a camshaft, if they are putting it in a crappy engine? Once a powerful 6.5 diesel is built, more people will realize the potential these engines have.
This is what I say to people who think a 6.5 diesel can't be powerful "It's just an engine"
Keep the questions coming buddy
