Part#'s for 6.5
bud9899
Recruit
SE, GA
Bellow is a spreadsheet that is packed full of part numbers for the 6.5. The spreadsheet was a gift from P.Cox and can be downloaded to your pc. I'll be glad to edit any info along with adding anything. I'm gonna try and convert it in word then post it as a long long post so it would get the part#'s search able on the site.
  • 65partnumbers.xls
Below is the spreadsheet converted into a text document that is searchable through the website.
You can also use CTRL+F to open a search box for the page.
Any data found to be incorrect let me know so I can change it, don’t want anyone getting the wrong part. When you see "Unknown" that means the manufacturer was not listed.
#1 Resistor OEM - 12561886
#2 Resistor OEM - 12561887
#3 Resistor OEM - 12561888
#4 Resistor OEM - 12561889
#5 Resistor OEM - 12561890
#6 Resistor OEM - 12561891
#7 Resistor OEM - 12561892
#8 Resistor OEM - 12561893
#9 Resistor OEM - 12561894
10 Blade 20" Plastic Fan AC Delco - 15010202
4L80E I/O Speed Sensors OEM - 24203876
4L80E Upgrade to 5288,5521,etc IP Unknown - BPAA 16216871
4x4 actuator 97 K2500 OEM - 26060076
4x4 actuator harness 97 K2500 OEM - 12376317
9 Blade 20" Steel Fan AC Delco - 15992650
Accelerator Pedal Assembly w/Position Sensor OEM – 15751307, AC Delco - 213-2820
Air Cleaner Gasket Felpro - 60555
Air Filter CarQuest-88441,
Alternator 98 K1500 OEM – 10463940
Balancer belt pulley (crank pulley) 97 K2500 OEM - 12557345
Boost Sensor 97 K2500 OEM - 12569241
Braided Metal Ground Straps OEM - 12157185
Braided Metal Ground Straps OEM - 12132154
Brake/Stop Light Switch OEM – 93801734, AC Delco - D1565E
CDR Valve 98 K1500 OEM - 25098706
CDR Valve NAPA - 2755788
CDR Valve 94 NAPA - CRB29445
CDR Valve 96 C3500 OEM - 25098706
Connector for ISS/OSS OEM - 88987978
Coolant Sensor Carquest - 207803
Cooling Radiator Surge Tank 97+ OEM - 15156662
Cooling Radiator Surge Tank 95-96 OEM - 15678943
Cooling System Seal Tablets AC Delco - 12378254
Covers (TSB 67-71-53A) OEM - 16244781
Crankshaft Positioning Center (CPS) OEM - 12557046
CTS Sensor 94 F OEM – 25037332, AC Delco - 213-77
Drive Belt Tensioner 96 C3500 OEM - 12561092
Dual Thermostat Housing OEM – 12553405, AC Delco - 1580782
Dual Thermostat Outlet OEM – 12564276, AC Delco - 151753
Dummy Pulley AC Comp - Mount. Bracket Unknown - Z39-107-C1
Dummy Pulley AC Comp - Pulley OEM - 12555023
ECT Sensor OEM – 15326386, AC Delco - 213-928
EGR Valve Gasket (EGR Tube Gasket) 94-99 S engine OEM – 10191428, AC Delco - 219-167, NAPA - 2-25203
Engine Block Fittings - Stock Oil Lines 94-95 OEM – 15718023
Engine Block Gasket OEM – 12551502
Engine Oil Cooler Inlet Line 95 Unknown - 625-143 LH
Engine Oil Cooler Outlet Line 95 Unknown - 625-114 RH
EPROM OEM – 16244788
Exhaust Manifold Gasket Felpro - MB 91587
Front Brake Pads -2WD 8600GVW OEM – 18025354
Front Wheel Bearing Grease Seals -2WD 8600GVW OEM – 15651661
FSD/PMD Male Plug End OEM – 10191640, AC Delco - 296-01
FSD/PMD Female plug Delphi - 12066317
FSD Male plug Casper Electronics 410015
Fuel Cap 98 OEM - 15763229
Fuel Filter OEM – 88915464, Carquest – 86376, Baldwin – BF1201
Fuel Filter for Fuel Filter Manager OEM - 10463940
Fuel Filter Gasket Felpro - 95786
Fuel Heater Gasket OEM - 12511962
Fuel Heater w/gasket OEM – 12511962, Stanadyne - 31341P
Fuel Manager Filter Screen Stanadyne - 29244
Fuel Return "O" Ring Felpro - 95761
Fuel Tank Module AC Delco - 25027459
Glove Box Latch 94-95 OEM - 15545967
GM Downpipe Flange Gasket OEM - 15954812
GP Controller 94-00 OEM - HDC907
GP Relay 97 K2500 OEM - 12496472
GP Relay Carquest - RY-383
GP Relay 94 O’Reilleys - BWD GPC5
GP's 6.2 C/J Unknown - HDS306, NAPA - 601-2091
GP's 94-00 Unknown - HDS309
Harmonic Balencer 97 K2500 OEM - 10154688
Head Bolt Tap Size 12m-1.75
Head Gasket Set 82-93 6.2L OEM – 14044934, Felpro - HSU 8726
Head Gasket Set 92-99 6.5L
Headlight Dimmer Switch 94 F OEM – 26019660, AC Delco - D834
Heater Hose Quick Connect Barbed Fitting 99 OEM – 15963984, AC Delco - 15-30569
Hydra. Boost Carquest - BBO527358
IAT Sensor 97 K2500 OEM - 25037334
Ignition Starter Switch NAPA - ECHKS6196
Ignition Switch Actuator NAPA - BK6202246
Ignition Switch Lock Cylinder NAPA - ECHKS6043
Injection Pump Swap Gasket 1 OEM - 10137486
Injection Pump Swap Gasket 2 OEM - 10137537
Injection Pump Swap Gasket 3 OEM - 12531704
Injector Seal Washer (copper washer)Felpro - 91600
Injector Socket Unknown - S6128, NAPA – BK 7002470
Injector/IP fuel return line kits (Diapaco) D14066305
Injectors 6.5 TD Delphi – 6703803, Stanadyne - 37818 10233973
Injectors 6.5 NA Delphi – 6703802, Stanadyne - 38272 10233972
Intake Manifold Gskt Felpro - 91585
Intake Plenum Gasket (upper intake) Felpro - MS90671
Intake, Plenum, EGR Gasket Set 94-99 S Felpro - MS-15306-A
IP (310HP "Marine" 6.5TD) Unknown - db2831-5722
IP (250HP "Marine" 6.5TD) Unknown - db2833-4974
IP (Stock '92 and '93 6.5TD C/K) Unknown - db2831-4911
IP Eprom (DS4-831-5068) Unknown - BPBN 16244854
IP Timing Tool Unknown - J-29872A
IP Wrench (15mm bolts) Unknown - J-41711
Lift Pump 98 K1500 OEM - 25117340
Lift Pump 97 K2500 OEM - 15754298
Lift Pump Carquest - E3309
Lift Pump (Higher PSI) OEM - 25115224
Lower Rad. Hose 96 C3500 OEM - 15683910
MAP Sensor 95 K3500 OEM – 12569540, AC Delco - ECHKS6043
Motor Mounts OEM - 15659675
Nylon Rocker Arm Retainers OEM - 23500076
Oil Cap OEM - 12553195
Oil Filler Neck 95 OEM - 12556499
Oil Filler Neck 6.2L OEM - 14071059
Oil Filter 2qt 97+others Baldwin - B7
Oil Filter Carquest - 85060
Oil Filter Adapter Seals (2 small O-rings) 94-95 OEM - 23500360
Oil Filter Adapter Seals (Big O-Ring) 94-95 OEM - 12559095
Oil Filter Adapter Seals (Copper Gasket) 94-95 OEM - 23500358
Oil Pressure Sending Unit 97 K2500 OEM - 12555492
Oil Pressure Sensor Carquest - PS262
Oil Pump
OPS Unknown - OPS132
OPS Socket Unknown - LIS13250
Optic Sensor Filter OEM - 12553327
Optical Sensor Filter Harness OEM - 12553327
O-ring (4x4 oil filter adapter) 98 K1500 OEM - 12559095
O-ring (4x4 oil filter adapter) 98 K1500 OEM - 12559583
O-ring (4x4 oil filter adapter) 98 K1500 OEM - 12559584
OTC Wheel Bearing Locknut Socket Unknown - 7090A
Outlet 97+ OEM - 12564276
Outside Mirrors - Black, power, non-heated 1 OEM - 15764757
Outside Mirrors - Black, power, non-heated 2 OEM - 15764758
PCM OEM - 88963802
Pigtail Socket Carquest - S638
Pitman Arm 96 3500 HD OEM - 26033290
PMD Kit OEM - 12561590
PMD Kit OEM - 12562836
Radiator 96 C3500 OEM - 52491622
Radiator cap 96 C3500 OEM - 10409635
Rear Axle Seal 98 K1500 Autozone – 710105, O’Rielley 710105
Rear Axle Seal KIT Unknown - 28446
Serpentine Belt Carquest - K061010
Serpentine Belt (VP removed) OEM – 4061010, Carquest – K061010
Starter (reman) OEM – 19136221, AC Delco - 336-1912
Starter Bolt 97 Unknown - 72181
Starter Motor Bracket OEM - 14028931
Starter Motor Bracket OEM - 23502557
Starter Solenoid OEM – 10456454, NAPA - ST151
Thermal Pad Stanadyne - 30598
Thermostat Unknown – 12551496, AC Delco - 12559338
Thermostat (195 for dual) OEM – 12559336, AC Delco - 131103
Thermostat Gskt Felpro - 35710
Timing Chain/Sprocket set (Cloves) 94-00 Unknown - C-3097
Timing Cover Set 82-00 6.2/6.5 (all) Felpro - TCS 45554
T-Stat 97+ OEM - 12559336
T-Stat X-over 97+ OEM - 12553405
T-stats Carquest - 32089
Turbo Oil Return 1" Hose OEM - 10149660
Turbo Oil Return Flange Gasket OEM - 14098654
Turbo Oil Return Pipe to Block pipe hose OEM - 10149660
Turbo Oil Supply Line OEM - 12562378
Upper Rad. Hose 94 Unknown - 61530
Upper Rad. Hose 96 C3500 OEM - 15977350
Upper Rad. Hose 97+ OEM - 15977350
Vacuum Lines ( S or F ???) OEM - 12559401
Vacuum Pump OEM – 7849209, Carquest - 64-1018
Valve Cover Gskt Felpro - 91599
Valve Stem Seal Felpro - 5112
Verticle Link Kit (Leaf Front End) 96 3500 HD OEM – 15635936
Water Crossover Gskt Felpro - 35357
Water Outlet Gkst Felpro - 35271
Water Outlet Gskt Felpro - 35289
Water Pump 97+ OEM – 88894036
WG Solenoid 98 K1500 OEM – 1997255
WG Solenoid 97 K2500 OEM – 1997255
WG Solenoid (w/foam filter) 94 OEM – 1997227
WG Solenoid tubes harness F OEM – 10236929
WIF Sensor O-Ring OEM – 12562378
Wiper Linkage (LH) 94 OEM – 12463067, Ac Delco - 12463067
Wiper Linkage (RH) 94 OEM – 15043370 AC Delco - 15043370
Parts list for adding a starter support bracket:
Qty___Part____________________....
1 = GM P/N 23502557...starter bracket
1 = M8x1.25x18mm bolt (holds bracket to block)
1 = M8x1.25 tap (if your truck's bolt hole is corroded)
1 = 8mm lock washer
2 = M10x1.5x113 bolts (if your starter bolts are broken)
Parts reference
I don't think we have one here yet ? If I missed it then maybe add this to it.
Flange Gasket for Downpipe to Cat/soot filter.
Gm#15954812
Nice! Well done! Lets keep it up. I will dig out my little parts book for the stuff I have had to figure out.
For you info:
Starter bolts- GM part # 15544950
Starter bracket (gm calls it just "brace")- Gm part # 23502557
Lower radiator hose Tee to overflow tank.
It's 3/4" on the Tee end, and 1" on the end that goes on the overflow tank. Don't bother with the one from NAPA (made by Gates); it's 5/8" on the Tee end and 1" on the other; it's deformed at the 1" end, and you gotta stretch it to go on the T end. It costs the same as the one from the stealer and the dealer item has new heatshield material already on it. NAPA doesn't.
GM 15031596 This is the hose that goes from the T (tee) on the lower radiator hose up to the surge tank (stealer calls it an overflow tank).
I searched for it here before I bought mine and couldn't find it. It was $36 locally. I couldn't wait for a Partszoneonline or GMPartsDirect order to crawl its way across the country.
If anyone wants to use Autolite Glow Plugs, they say they are 60G replacements, quick heating, the number on the box of 4 is 1112, got them from NAPA about a year ago. They are made by Honeywell.
Two hard to locate items
Most GM parts guys give you the deer in the headlights look when you ask
Cylinder head dowel sleaves (GM calls them dowel pins) #12558081
Oil pump to shaft plastic coupler #477249
Aftermarket has yet to offer these, or at least I can't find them
Oil pumps come with the coupler but you can't get one by itself
The plastic coupler is sweet if your pump is Ok and you just want to clean and reinstall.
Have a shaft fall out OMG what a PITA.
Best MGW
Dealership part number for block heater and cord. $42 even
12343981
Cab mounts for a '93 regular cab 3500. Could be used for others as well. Check dimentions. Also called cab cushions.
All GM.
Front upper- 15567808, Upper measures 1 7/8" from mounting surface to mounting surface.
Rear upper- 15567810, Measures 2 3/16"
Lowers- 15706378, Lowers are all the same, F+R.
Hey this is a nice piece of work guys but as always every job can be improved, as a newbie I feel that other newbies and other people less aware of the totally awesome capabilities of this forum would find this stickie very easily and use it to buy a part that is not only not as good as the vendors on this site but also more expensive. What we need is a statement in the beginning stating that the FIRST list of parts and numbers are supplied by the VENDORS on this site and then the next list are the outside vendors and GM part numbers! As an example we dont want someone buying a expensive PMD and fryng it when they can get one from Leroy @ PMDCABLE on a extension that will prolong its life or many of the other superior venders here at TTS. Gotta take care of us newbies, we be sorta....well....dumb....LOL WE owe this to the vendors and to the public, after all u diesel dudes are really awesome.
Here are some useful part numbers I was aske for recently.
They may duplicate previous posts, but then maybe not.
The filter bypass is #25014006
Cooler bypass is #25161285
The plug for the Cooler bore (goes on top and has the little hole) is
#14066310
The late squirt nozzles are a #12561141
The little oil pump drive shaft plastic connector that goes at the
pump and keeps the shaft in is a #00477249
Rocker arm retainer buttons are a #23500076
The metric bell housing bolts for late blocks uses a #15724226 bolt that has a metric stud top
The new style crank dowel pin that goes in the flex plate end is a
#10046031
This is a roll pin type
CTS Coolant temp sensor/switch in the T-stat crossover for a DB2 truck. Ac Delco Part # 10154649... This sensor/switch is for the cold high idle and advance function on a mechanically injected 6.5/6.2. Two male spade terminals side by side. '93 and earlier.
