p206
tammlyn
timmins ontario canada
my truck just threw a p206 open circuit injector #6,i think i reasd somewhere before about wiring harness issues but i cant find the article can anyone confirm this thanks mike
You need to check the wiring to the injector, if it looks good then you need to check the resistance on the #6 injector and see if it is within spec. Also remember, #6 is the 2nd from the back on the drivers side.
For a P0206, I would be checking the harness and injector resistance before I even thought of doing injectors. If you do find a bad injector coil, then I would only change the one out. But diagnose it before you go throwing an injector in it.
Correct me if I'm mistaken, but couldn't you just swap injector #4 and #6. Clear the code. Then if you get another p206 it is in the wiring, A p204 would then indicate the injector is the problem.
Thats one way of doing it, and yes this would show the problem.
