tanman_2006
Just a farm kid...
Elaborate a bit please Jeff.
Kennedy diesel (GM Diesel Supporter) has a dual lift pump set up. Also available in a single set up for those that dont plan on going much past stock - +100hp
Closer to 390 would be my guess at the wheels. I know I'm running in the 390-400 range at the wheels with my BURB(many would say I'm being rather conservative with my estimate after riding in it) with a single, and have no problems holding rail pressure. The biggest reason for needing a lift pump is to combat acceleration. The harder you accelerate, the harder the CP3 has to work to move fuel. This is why many can hold rail pressure on the dyno at 500HP without a lift pump, but if you do it on the track it will drain the rail out in no time. The single KENNEDY lift pump at 13 volts can move right at a gallon a minute of fuel after the factory filter set-up. Ttested it on my truck, and I could fill a 5 gallon can of fuel in right at 6 minutes. That's enough fuel to support roughly 650HP, but when you add in pushing the fuel up the line against G forces of acceleration you are back in the 400-450HP range(to be safe). Another mod you can do is to open up your filter head and take right at 2 rings of the main check ball spring off to lessen the amount of vacuum needed to pull fuel through the filter head. I checked a new filter head with a vacuum pump, and found it took almost 20 inches of vacuum to fully open the check ball(it took 5 inches of vacuum before it even flowed). I know I gained almost 3000 PSI of rail pressure with my failing CP3 by modifying the filter head check ball spring.I am at +85 (so 445 HP) on the Predator. I suppose I should have the dual setup. Eventually I'm probably going EFI though. Unless, of course, a lift pump eliminates the 2nd gear stumble with the Predator.
...Another mod you can do is to open up your filter head and take right at 2 rings of the main check ball spring off to lessen the amount of vacuum needed to pull fuel through the filter head. I checked a new filter head with a vacuum pump, and found it took almost 20 inches of vacuum to fully open the check ball(it took 5 inches of vacuum before it even flowed). I know I gained almost 3000 PSI of rail pressure with my failing CP3 by modifying the filter head check ball spring.
Yeah, yeah I know...You need to get the tall can spin-ons Mike!![]()
Yeah I've never seen one that bad before even at 15k+ a bit. Truck was just fine until I decided to save a few miles and buy at a less frequently used Mobil in town. Next two days did it in.Wow, mine typically make 10-12k and still look clean.
