- Staff
- #41
If the MOBIL DELVAC is truly a TRANSYND copy, then don't be aarmed after 5000 miles when it starts to turn orange or brown. TRANSYND has a problem with the dye they use not staying red in color. The fluid may appear to be burnt because it will eventually turn brown, but it will be fine. You can get it up to around 325 degrees before it does any real damage to it(you have to keep in mind to add 80 degrees to sump temp to have a rough idea what the fluid temp is coming out of the pump).
