vegtech
WVO Enthusiast
I had the same problem with a 4l60e truck. It ran me through the ringer. Turned out to be a bad ignition switch. Check all the grounds
Sent from my ADR6350 using Tapatalk 2
What are you going to call her?
I like the TracRac on the white one. I have one and use it all the time.
So glad you did not name it Leroy like some other member did. I won't mention any names (Tanner)
glad to see you got it home!
16 inch rubber, 4L80E, and a 3.73 9.5 14 bolt should keep you happy on trailer duty.
I assume since this one has arrived, the supple springs will stay on the C1500? I bet a roadmaster active suspension would help out if its a little too saggy.
also, I see we are tied for 1995 rigs in the sig. :thumbsup:
