chefmike
Not just a truck... a project.
I can't find my original thread, so I started a new thread.
I had an ABS light and occasional limp mode. Output sensor fixed the ABS, but I am still going into limp. It was fine for a while, then started back. It throws codes for slipping and pressure solenoid. Silly me, i figured it was telling the truth: I dropped the pan, changed the filter, swapped out all the 4 solenoids and the pressure board, as well as did a new harness. The plug had atf in it. I cleaned it out with contact cleaner. Put it all back together. Drove great, shifts fantastic.
And went into limp when it got to temperature. It is always after 10-15 minutes, then lIMP.
So I tried to order a adld cable to run scan tech, but the site was down. In the mean time... Other thoughts? Tomorrow I will check cables on top. Other thoughts include brake switch (not sure where it is, but it powers tcc lock up, which could over heat trans and limp it?) VSS buffer? i have on non-stock tires... 235-85? I will double check. Its what some folks were running for better mileage. This problem has been intermittent since the tires got put on now that i am thinking about. Growing in frequency. could that be the source?
Throw me some bones here! Oh, I checked the grounds by the trans dip tube and cleaned them.
