L98TPI
Make sure your fabrication skills are top notch. And wear safety glasses. Trust me.most guys make one from an old GP
There are TH350(C)'s TH250C Th200's and so on that have dual chevy and BOP (Buick Olds Pontiac) patterns. But no 700R4/4l60(e) 4l80E's & Th400's that did. Some few had V6 bolt patterns (S10,Astro) and even Jaguar patterns (TH400). TH400's can be found with BOP patterns since they were used in the big boats behind big engines.Chevy bell housing bolt pattern is different than the other GM's
You know. racers cut the bell housing off TH400's and bolt on with the pump bolts a race legal version that acts like a scatter shield. I am wondering if you could get a blank one of those and put it on a 4L80E and drill it for ??? Cummings Isuzu Perkins Navastar![]()
Its the later models that can have a dual pattern. For instance I have a TH350C that was behind a 89 Olds diesel that is Chev/BOP.I've not paid attention then, never knew they had two bolt patterns on one bell housing.
I would be interested to hear more about the cutting off of a bell housing and installing the scatter shield. That could potentially be a good way to go. Are these the scatter shields I see in Summit?
There are few things that give me any relief. My chiropractor, my inversion table, my hot tub. Exercise? Nope. Not after 3 shoulder surgeries, crushed T-12 vertebrae, bad lower spine, bad knees, and the ball of one foot pounded into pieces. I am down to about 233, from a high of 286, and it has taken about 2 years to get here.
What makes it rough is days like yesterday. Had to work on the building, had to trim some trees... and that extending saw/pruner is a bear, with bad shoulders and back. I took it easy today, but will be back at it tomorrow. I do not like pain pills. Ten hydros is a 12-18 month supply for me. I am trying some extended release Tramadol, but the nausea is about as bad as the pain. Not sure I don't prefer the pain. I will get through it though, I want my truck running again.
X3 back, knee, hip, sholder, messed up from, a fall in my teens, motorcycle accident, fall in the drained pool, fall through the porch, fall off ladder/scaffolding, and a few others. Doc said years ago its a wonder I can walk at all.X2 on the hot tub that & I also use epsom salt baths 3~4 times weekly, both help me. Wish ya were closer to us up here in Ill. we'd give ya a hand trouble shooting yr truck...
Those places are doable for me. Since the wife has been wanting to go there any way. :hihi:No idea on that, but I am a member of some motorcycle forums... two of them meet in Pigeon Forge, TN yearly, and one of them meets in Maggie Valley, NC yearly.
Sounds like a fun idea.
