Finally got around to doing a little rewiring today for the LP, bypassing the stock wiring, and running straight to the LP. I never did hear the pump operate, and the truck still ran very rough. Power seemed okay, but very rough. While at the shop, it died, and did not want to restart. Chuck shot some break cleaner into the air filter, and it finally did fire, spat out a large cloud of black smoke, ran at about 2300-2400 rpm for a few seconds, and then died again.
My mechanic freely admits that he does not know diesels, but around here, he is all I've got. I may have finally located a diesel mechanic, and depending on the information I read here, I may take the truck to him.
According to my mechanic, he believes that I have a serious problem, maybe even a hole in a piston. Am I right in thinking that is a little premature? He is also thinking that the response to the brake cleaner is an indication of low compression.... THAT one, I just do not "get".
His council is that if it IS a "gone motor", put in a big block. Well, I might be alright with that, if I could find a donor vehicle, so I had everything I needed. The donor would have to be cheap though, because I am operating off savings, not having gotten a regular paycheck in over 3 years. That brings me to the rebuild question. Assuming that I do have compression issues, is this like on a gas engine, where new rings, and bearings, oil and water pumps, and a valve job might not be so out of reach as to be impractical? I was looking at gasket set pricing on ebay, and they did not seem to be outrageous. How does the diesel weight compare to the weight of a big block?
I guess I just need to figure out what is up with the 6.5, before I start planning for a BB. The way my luck has been running though, I am looking.
