MrMarty51
It might not split if You use a plasticated hammer, but, if You use a ballpeen or any kind of hammer with a steel head, it will split them wood handles. I was told this by an old timer that had the same sxperience after I had already split the handles on a brand new snap on scraper. That was an expensive lesson that I will soon not forget.Full tang!! That’s what I was trying to remember.
The wood is two different pieces riveted to each side. It won’t split Marty.
As far as what has to come off to remove cover- that is why WW was saying ignore it. Total pain in the butt job.
Turbo and injector lines. I can’t remember what hang ons might be in the way. By time you get there, you will be able to see very easily if their is any missing bolts.
